Old 01-06-2012, 05:30 PM   #1
Yaristeve
Drives: 3-door hatch
Originally Posted by PHXDEMON View Post
Just got my new 16" RPF1s with sumitomo tires from tire rack in only 3 days The enkei center caps are ugly and 100 bucks a set. I have found a lot of alternatives that are cheap but they are all relatively flat and wont clear the front axle. The size is 63mm.
pic of the new wheels.
Can you do me a favor:
Can you see what the Maximum Load Capacity is? It should be cast somewhere on the backside of the wheel. No wheel manufacturer's website has this information and nowadays, wheels are mounted to the wall so I can't go in and check myself.
TIA.
Oh, and BTW, looks nice. What is the width and offset and tire size?
Old 01-06-2012, 06:52 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
TIA.
the tires are 205/50/16. The wheels are 16x7 not positive on the offset it was just whatever tireracks calculator picked. the only thing on the back/inside of the wheel was a quality control sticker and a number 72 stamped on the back of it. The rpf1s are highly regarded for how light/strong they are so I can imagine they will take whatever weight the Yaris suspension can handle. If you are lowered like I am I would recommend going with a slightly thinner tire because the only rubbing I have is when the wheel is cranked all the way.
Old 01-06-2012, 07:06 PM   #3
Yaristeve
Thanks!
I am actually looking for 16inch wheels for my IS300. I believe its curb weight is 3,400lbs, quite a bit more than a Yaris. I am just tired of the low profile tire look. To me, 50 series tires are low enough; mainly because I like the slight "poofiness" of the sidewalls with a slightly higher profile; Stock IS300 tires are 215/45-17 and I want to go to 225/50-16.
I has hoping there might be a casting that says, "xxx kg" where xxx = about 600.
How much is your car lowered and with what setup? It looks like the perfect setup I am thinking of.
Oh well. I really appreciate that you took the time to look anyway!
Old 01-08-2012, 11:22 PM   #4
PHXDEMON
PHXDEMON's Avatar
Thanks!
its dropped on tanabe df210 springs. I believe its like a 2 inch drop all around. when I bought the car it had 215./45/17s which were awful and rubbed if I ran over a stick.
Old 01-09-2012, 12:10 PM   #5
Yaristeve
Are the fenders rolled or shaved or modified in any other way? I've been thinking of going 16" as well...
Old 01-11-2012, 12:21 AM   #6
PHXDEMON
PHXDEMON's Avatar
rear fenders are rolled and rear wheel well liners are removed. With a slightly thinner tire you would probably be fine.
center caps for 15" steelies? Lewis Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-02-2018 02:50 PM
Steel Wheel Center Caps BassAssassin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-17-2010 02:20 PM
center caps for enkei rpf1s??? andruboz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-05-2010 10:37 PM
TOYOTA center caps and Trim Rings for sale. coffiend Items for Sale by private party 10 05-11-2010 06:29 PM
custom center caps? or vitz center caps BrazdonW Cosmetic Modifications (Exterior/Interior) 2 09-06-2009 11:21 PM
