Old 01-06-2012, 07:06 PM   #1
Yaristeve
Drives: 3-door hatch
Originally Posted by PHXDEMON View Post
the tires are 205/50/16. The wheels are 16x7 not positive on the offset it was just whatever tireracks calculator picked. the only thing on the back/inside of the wheel was a quality control sticker and a number 72 stamped on the back of it. The rpf1s are highly regarded for how light/strong they are so I can imagine they will take whatever weight the Yaris suspension can handle. If you are lowered like I am I would recommend going with a slightly thinner tire because the only rubbing I have is when the wheel is cranked all the way.
Thanks!
I am actually looking for 16inch wheels for my IS300. I believe its curb weight is 3,400lbs, quite a bit more than a Yaris. I am just tired of the low profile tire look. To me, 50 series tires are low enough; mainly because I like the slight "poofiness" of the sidewalls with a slightly higher profile; Stock IS300 tires are 215/45-17 and I want to go to 225/50-16.
I has hoping there might be a casting that says, "xxx kg" where xxx = about 600.
How much is your car lowered and with what setup? It looks like the perfect setup I am thinking of.
Oh well. I really appreciate that you took the time to look anyway!
Old 01-08-2012, 11:22 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by Yaristeve View Post
Thanks!
its dropped on tanabe df210 springs. I believe its like a 2 inch drop all around. when I bought the car it had 215./45/17s which were awful and rubbed if I ran over a stick.
Old 01-09-2012, 12:10 PM   #3
Yaristeve
Are the fenders rolled or shaved or modified in any other way? I've been thinking of going 16" as well...
Old 01-11-2012, 12:21 AM   #4
PHXDEMON
PHXDEMON's Avatar
rear fenders are rolled and rear wheel well liners are removed. With a slightly thinner tire you would probably be fine.
center caps for 15" steelies? Lewis Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-02-2018 02:50 PM
Steel Wheel Center Caps BassAssassin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-17-2010 02:20 PM
center caps for enkei rpf1s??? andruboz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-05-2010 10:37 PM
TOYOTA center caps and Trim Rings for sale. coffiend Items for Sale by private party 10 05-11-2010 06:29 PM
custom center caps? or vitz center caps BrazdonW Cosmetic Modifications (Exterior/Interior) 2 09-06-2009 11:21 PM
