There are two ignition wires on the Yaris - The Pink wire and the Green Wire on the ignition switch connector. The pink is the primary, so try that first, but the green may also be necessary to keep it running. If that turns out to be the case, you will need to have the turbo timer switch a dual pole relay and then connect the relay to the two circuits.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| turbo timer | Scubaru Steve | Forced Induction Forum | 5 | 07-04-2011 07:19 AM |
| HKS Turbo Timer | Nas_RS | Cosmetic Modifications (Exterior/Interior) | 8 | 10-23-2009 07:39 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
