Adding USB ports for charging
my latest and greatest idea is adding a few USB ports for charging things, phones, gps, etc etc. has anyone done or attempted this? I'm thinking of adding four total, two to the right of the cig lighter, and two either in one of the glove compartments, or in the slot next to the e-brake handle.
and a question towards CtScott, if he reads this. I'm doing research to figure out how to get it down to correct voltage, but you may know faster than me. What would i need to get it proper? So, keep your heads up, this may be done pretty soon :) |
You need a 5V regulator circuit to drop the 12+ Volts down to 5.0V. The easiest way to do so is to purchase a premade one, gut it and mount it as you want it. This Griffin one would be a good choice:
http://www.buy.com/pr/product.aspx?s...lerid=22498279
I've been researching this myself. LM7805 and LM2576 come to mind since I'm looking to power an ipad (2A). This person made a guide with a 7805:
http://timothyb.net/DIY_iPad_2_USB_Charger.html |
#4 | |
Don't know why i didn't think of gutting a premade one, that would be a lot easier. I got the idea from looking at the usb charger i have. Lol. Maybe I'll gut it and add a second port, also. i think that little square spot by the cig lighter would be just the right size. i need to fill it anyhow, i kinda' broke the tab when i was fidgeting with it seeing if it was removable.
i wanted to do that, but then i found a "bullet" usb adapter for the cig. lighter. I obtained it right before i got laid off :) There's a slight issue that causes my radio to static a little bit but its not at all annoying. (I use an ipod video out connector to attach to my scion monitor)
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
You might also want to take a look at a previous DIY:
http://www.yarisworld.com/forums/showthread.php?t=9431 Sounds like this is what you want to do with that area by the 12v Outlet. |
Well look at that! guess I'm not the only one who had the idea, lol.
| DIY Powered USB Ports | BailOut | DIY / Maintenance / Service | 27 | 02-22-2017 10:17 AM |
| 12v port modification for extra ports, USB's, etc. | tire | General Yaris / Vitz Discussion | 12 | 06-13-2011 08:45 PM |
| YARIS/VITZ 2006 - USB Connector on Dashboard or Console | jojozep2008 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 04-19-2011 11:41 AM |
| HELP needed for carputer project: Powered USB hub install | Astroman | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 11-01-2010 05:18 PM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
