Old 01-16-2012, 12:35 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by Vang View Post
how's the turning radius? easier/harder/no difference when parking in cramped spots?
also any major blind spots?
The SE's turning radius is bigger than other Yaris models. I believe Car and Driver said it had something to do with the larger wheels or something. It was still good. It was a amazingly quick, though which is great in cornering and maneuvering around town. Visibility was excellent.
Old 01-16-2012, 02:52 PM   #2
Jason@SportsCar
The 2012 has a nearly 2" longer wheelbase, that is where you lose the turning radius - but the change is so small most people will never have an issue or notice it.
Old 01-16-2012, 05:49 PM   #3
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
2011 Yaris turning diameter = 30.8'
2012 Yaris L = 30.8'
2012 Yaris SE = 36.7'
So, 2" longer wheelbase didn't affect the turning diameter.
SE's steering ratio or whatever the reason made turning radius to be almost 6' larger. I think I would notice 6' difference in turning diameter.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 01-16-2012, 06:04 PM   #4
03Z33
03Z33's Avatar
Drives: TCR10
I'm sure the wheel size and longer wheelbase contribute to the wider turning radius some but you're missing the best part:
2012 Yaris SE ONLY have a different steering ratio (tighter rack)!
L, LE models get the normal sloppy rack, it makes a very noticeable difference in steering feel and response :)
According to Toyota specs the electric power steering in the SE model is also "sport calibrated" which may make the steering feel heavier.
2012 L, LE Specs:
Electric Power Steering (EPS); power-assisted rack-and-pinion
Turning circle diameter, curb to curb (ft.) 30.8
2012 SE Specs:
Sport-calibrated Electric Power Steering (EPS); power-assisted rack-and-pinion
Turning circle diameter, curb to curb (ft.) 36.7
Old 01-16-2012, 06:15 PM   #5
Jason@SportsCar
2012 L, LE Specs:
2012 SE Specs:
Where does it say the ratio is different? Steering ratio will effect how quickly the wheels turn in response to your input, but will have no effect on turning radius. The only reason for a bigger arch is the longer wheel base, and if they put a steering limiter in place to prevent the "larger" SE wheel/tire combo from rubbing the inner fenders.
Old 01-16-2012, 07:05 PM   #6
tetzyamis
'09 5dr
tetzyamis's Avatar
SE
Steering gear ratio = 46.17
Lock to lock turn = 2.3 turns
Turning circle = 36.7 ft
None-SE
Steering gear ratio = 49.93
Lock to lock turn = 3.0 turns
Turning circle = 30.8 ft (which means the longer wheel base than the previous gen Yaris did not affect the turning circle)
Old 01-16-2012, 07:12 PM   #7
Jason@SportsCar
Originally Posted by tetzyamis View Post
SE
None-SE
They actually made the new car turn sharper than the previous gen.
Steering Ratio (:1), Overall: 19.7
Lock to Lock Turns (Steering): 3.0
Turning Diameter - Curb to Curb: 32.6'
Old 01-16-2012, 07:50 PM   #8
tetzyamis
'09 5dr
tetzyamis's Avatar
32.6' is for the sedan.
liftback is 30.8', which is the same as none-SE 2012.
2012 Yaris Discussion elijahsami Third Gen Yaris General Discussion 213 02-07-2011 10:58 AM
Subcompact Culture celebrates its one-year birthday Thirty-Nine Off-topic / Other Cars / Everything else Discussions 5 04-14-2009 02:42 PM
