#1 | |
#2 | |
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
2012 Yaris L = 30.8' 2012 Yaris SE = 36.7' So, 2" longer wheelbase didn't affect the turning diameter. SE's steering ratio or whatever the reason made turning radius to be almost 6' larger. I think I would notice 6' difference in turning diameter.
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
#3 | ||
2012 Yaris SE ONLY have a different steering ratio (tighter rack)! L, LE models get the normal sloppy rack, it makes a very noticeable difference in steering feel and response :) According to Toyota specs the electric power steering in the SE model is also "sport calibrated" which may make the steering feel heavier. 2012 L, LE Specs: Electric Power Steering (EPS); power-assisted rack-and-pinion Turning circle diameter, curb to curb (ft.) 30.8 2012 SE Specs: Sport-calibrated Electric Power Steering (EPS); power-assisted rack-and-pinion Turning circle diameter, curb to curb (ft.) 36.7 |
#4 | |
#5 | |
'09 5dr
Steering gear ratio = 46.17 Lock to lock turn = 2.3 turns Turning circle = 36.7 ft None-SE Steering gear ratio = 49.93 Lock to lock turn = 3.0 turns Turning circle = 30.8 ft (which means the longer wheel base than the previous gen Yaris did not affect the turning circle)
#6 | |
Steering Ratio (:1), Overall: 19.7 Lock to Lock Turns (Steering): 3.0 Turning Diameter - Curb to Curb: 32.6'
#7 | |
'09 5dr
liftback is 30.8', which is the same as none-SE 2012.
| 2012 Yaris Discussion | elijahsami | Third Gen Yaris General Discussion | 213 | 02-07-2011 10:58 AM |
| Subcompact Culture celebrates its one-year birthday | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 5 | 04-14-2009 02:42 PM |
