Old 01-18-2012, 01:04 PM   #1
Crackerballer
Drives: 08 BMW 135i
Derick I want to bump this and ask if you think 2 tiles per door will help with road noise and some help to sound quality. I am mainly looking to eliminate road noise, so not anywhere as extreme as what you're doing, but just a bit quieter. I was thinking of doing the doors and the floor. Not going to tackle the firewall, may also do the spare wheel well and trunk too. Thanks.
Crackerballer is offline   Reply With Quote
Old 01-18-2012, 02:20 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
CB...
2 CLD Tiles per door it will do almost nothing that you could perceive while driving,
blocking road noise is more of a "ON" / "OFF" thing CLD Tiles will prevent large flat sheet panels to reverberate but CLD Tiles alone will not block noise.
These 2 CLD Tiles help making the door a better speaker enclosure, but for that I would use MAT, a cheaper version of CLD Tiles and conver as much
surface as possible inside the door.
A layer of MLV with your 2 CLD Tiles per door and a thin layer of CCFoam will do what you want.
Covering the entire floor + wheel wells makes a big difference in road noise.
FYI, I used 5 CLD Tiles and maybe 24" of Rope, per door and losts of MAT.
(plus a layer of MLV, and CCFoam).
D.
CLA 250, 4MATIC
Old 01-18-2012, 02:27 PM   #3
yojabbajabba
Drives: 2008 YRS 5Dr LB (1.5L)
CB...
FYI, I used 5 CLD Tiles and maybe 24" of Rope, per door and lots of MAT.
D.
When doing the doors, where did you apply the RAAMMat? I understand how the CLD Tiles work, and where that goes (and how much) but in this entire SQ/road-noise-kill build I haven't figured out WHERE and WHY you are using MAT?
Thanks Derick.
yojabbajabba is offline   Reply With Quote
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
FlexSeal as sound deadening? Shinare In Car Entertainment + Electronics (audio / video / alarm) 11 06-18-2011 10:18 AM
