Old 01-19-2012, 02:08 PM   #1
Make sure when you tap the oil pan for the turbo oil return line you make it as high as possible. Above the oil level line. It will save U from problems later.
You'll be tapping the block, not the pan, just for clarity. The Yaris' pan is too shallow to tap into; it's more of a cap for the bottom of the block.
