Not quite a noob
Drives: e46 325 Join Date: Jul 2009
That's impossible.. it will need one eventually
And, the transmission actually knows when it needs to be changed. While I was doing my experimentation with bypassing the 4th gear lockout when cold, I found that when you read the data for the AT from the ECM that there is a parameter for the status of the AT fluid that says if it needs to be changed.
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
