Old 01-20-2012, 03:43 AM   #1
yojabbajabba
Drives: 2008 YRS 5Dr LB (1.5L)
Lets say I took care of road noise using CLD+CCFoam+MLV,
OK, now my Lows (50Hz-200Hz) are in the OEM doors location (lots of BASS here) the speaker needs an enclosure, (solid, rigid, vibration proof, acoustically treated, etc) how can I make the skinny door walls perform as I proper speaker box? adding mass to it's walls in my case I used MAT, inside the door an as much I could in the structure of the door to reduce vibrations, also applied behind the plastic panel that covers the entire door.
I would love to have my speakers in solid oak wood enclosures BUT... I can't the doors come in cheap metal and plastic.
Just for the record: 3 to 4 layers of MAT does block road noise, but you pay for that extra material and time.
D.
So basically ROAD NOISE is the goal with CCF+CLD+MLV (although it would help with acoustically treating the door). MAT is primarily there to counteract the active frequencies of the speakers. Is that correct?
Aaron
yojabbajabba is offline   Reply With Quote
Old 01-26-2012, 02:30 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Aaron
Yes.
D.
CLA 250, 4MATIC
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
FlexSeal as sound deadening? Shinare In Car Entertainment + Electronics (audio / video / alarm) 11 06-18-2011 10:18 AM
