![]() Drives: 2008 Yaris Join Date: Aug 2011
p2195 O2 sensor question
Hi all
2008 Yaris hatchback base here and the MIL just came on. Scanned it and got a p2195 O2 sensor code. (2 ofthe same code actually) cleared it and it came back on the following morning. any ideas? any idea on how to test or tell which O2 sensor? thanks in advance! |
#2 | |
Drives: yaris Join Date: Jan 2011
stuck lean signal, could be a bad connection could be a bad sensor |
alright so find a connector and clean it.
what about testing the sensor with a meter? anyone know what values I should see for resistance? would that be helpful or anything like it? |
and it would be this part then?
http://www.autozone.com/autozone/par...105_1784_97999 |
alright, so I took open the connector to the front o2 sensor and deoxited it. pulled the ecu fuse hoping it clears the MIL to see if it returns. while I was down there I got a 22m wrench on the o2 sensor from the bottom side and got it to turn a tiny bit but have nowhere to move the wrench to get any more turns out of it. any ideas? special wrench? take other stuff off? (please no)
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Back to Autozone: http://www.autozone.com/autozone/acc...er=272729_0_0_
thanks! I have to wait a week or so before I have the money for the sensor but when I go I will see if the zone will lone the tool. if not I guess $25 is not so bad.
