Old 03-14-2007, 01:11 AM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
With Sportivo shocks/struts, I don't believe your supposed to cut the bump stops. They are made for lowering springs (hence, they are shorter) and cutting the bump stops may accually allow the strut to fully compress. When the strut fully compresses the piston rod bottoms out. If this happens with enough force it will bend the rod thereby destroying the strut. Cutting the bumps only applies to stock shocks/struts with moderate drop springs. I would put full length bump stops back in there before you ruin them. Just my thought...
PetersRedYaris is offline   Reply With Quote
Old 03-14-2007, 11:01 AM   #2
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
exactly, its not the bumb stop getting hit, its the strut bottoming out.
punch is offline   Reply With Quote
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
