Old 01-20-2012, 02:56 PM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
interesting..
I dont mean to hijack your thread Jason.
I think I understand what your saying racerb, but could you PM me a picture of that setup. I am curious. Also that moving the seat further to the shifter is a good idea too. It would make shifting a bit more comfortable
-Derrick-
Old 01-20-2012, 07:57 PM   #2
racerb
interesting..
Sorry for continueing the hijack, but couldn't find any pictures of my steering column set-up. So here is a very simular set-up to mine on an MG, same basic deal hung verticle where mine hangs horizontal.
http://www.google.com/imgres?imgurl=...9QEwAw&dur=180
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 01-23-2012, 12:15 PM   #3
Jason@SportsCar
racerb
Similar to mine as well. Splined shaft with a quick release welded on. Simple, much lighter than stock, and further reduced the steering effort.
Old 01-30-2012, 12:06 PM   #4
Jason@SportsCar
Progress... Loynings head with Jun cams mated to the block. If I did not like my neighbors I would fire it up and do the break-in tonight. It will just have to sit till the weekend.
Old 02-08-2012, 12:37 PM   #5
Jason@SportsCar
The results are in, the Jun cams are an improvement over the custom grind we had done for the 2010 season, but they are not magic.
With the combination of head work and cams we picked up 12hp when compared to the stock engine we ran in 2011. However, just like with the custom grind cams we lost Tq below 5000rpm when compared to the stock engine - fortunately in this case we only lost 3ft-lbs, where the 2010 cams lost around 18ft-lbs.
While I was not jumping for joy at the final numbers, I was happy to see the top end power match our 2010 numbers, while regaining most of our lost Tq. Additionally, the power band with the Jun cams is much broader than the custom grind was, we have nearly 1000 more usable RPMs than we did before. From 5500rpm on we have more HP and Tq than either of the previous setups offered, and the power delivery is smooth.
If you are thinking about the Jun 9.5 cams keep in mind these are not a direct bolt-in. Your head will need relief cuts to clear the lobes, and without engine management you will not see the full gains.
Overall I give them a thumbs up, but expect to spend about $2k between the cams and head work.
Old 02-08-2012, 09:00 PM   #6
racerb
As a long time racer of low horsepower front drive cars, any gains with restrictive rules are a real plus. Learning how to get the most out of the loose nut behind the wheel, can actually make the biggest difference. Just look back in history at what those early racers did with the first Mini Coopers, cars that might have had 40 hp and tiny, skinny as hell tires. When you get to the point where your getting the most out of you the driver, then horsepower numbers aren't as big a factor in all out speed!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
