Old 01-21-2012, 12:03 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I could'v sworn I've already put my input forward but they are of decent to good quality. Mine haven't leaked- the halos are dim so I don't use them. The Cutoff is annoying, but at least you don't blind oncoming traffic. I dunno what more you can want in terms of opinion. ;)
Also, make sure you get a set with reflectors on the side if they're required in your state/province. They don't work very well, but it looks like you have reflectorss which won't be as noticeable as having nothin at all.
Old 01-21-2012, 12:34 PM   #2
MadMax
MadMax's Avatar
Thanks, that's exactly what I was looking for!
And I was just researching the side reflector issue, as I was going to get a set with clear ones but found that Texas law requires amber ones...
Sec. 547.353. COLOR REQUIREMENTS. (a) A clearance lamp, identification lamp, side marker lamp, or reflector mounted on the front, on the side near the front, or in the center of the vehicle must be or reflect amber.
(b) A clearance lamp, identification lamp, side marker lamp, or reflector mounted on the rear or the side near the rear of the vehicle must be or reflect red.
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995.
Granted, for a while I had clear ones on a previous car, and it never caused a problem. I think this portion of the transportation code is so obscure that most peace officers are not aware of it; but there is always the possibility of one knowing and receiving a 'fix it' ticket that would require opening up the lights to replace them. That's something I'd like to avoid if at all possible...
Cheers! M2
eBay Issue - Your help needed *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 02-04-2011 09:18 PM
WTB: Gauge Cluster w/tach for HB cdydjded Willing to Buy by private party 12 06-09-2010 03:49 PM
Cheap eBay LED Strip vs V-LED Strip Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 1 03-18-2010 08:06 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
ebay intake: would you? thebarber Performance Modifications 7 12-03-2008 12:44 AM
