Old 03-14-2007, 11:05 AM   #1
den37
den37's Avatar
Drives: toyota vitz
prob with my vitz
when i turn on the ignition both rev counter and speedo go right up and clock resets itself have been to toyota they have no idea with it being an import and ideas what it could be thanks
den37 is offline   Reply With Quote
Old 03-14-2007, 12:31 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Its happened to me before on other cars/trucks ive owned.
Have them check the charging system, each time it was a low or going dead battery.
Old 03-14-2007, 01:03 PM   #3
Chiefy707
XBox360 Fanboy
Chiefy707's Avatar
Drives: 07 Bayou Blue LB
Send a message via AIM to Chiefy707
Open your hood...
Then look in the fuse/relay box and see if there's a 15A dome fuse installed next to a 7.5A ECU-B fuse. If the 15A fuse isn't there that's your problem. Just take the 15A fuse from the spares (there should be 4) and install it in place.
The 15A fuse is supposed to be installed during the dealership's PDI and it's left out to avoid excessive parasitic drag.
If the fuse is there then you know it's something within that circuit. something that bothers me though is that your calling your car a Vitz meaning it's not a US vehicle meaning my advice is probably useless. If it is, I'll just STFU now ^_^ hope you get it fixed though.
Chiefy707 is offline   Reply With Quote
Old 03-14-2007, 09:11 PM   #4
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
have the ignition switch relay checked/changed could also check speedometer connector on transmission for loose connection
hystria is offline   Reply With Quote
Old 03-15-2007, 08:44 AM   #5
den37
den37's Avatar
Drives: toyota vitz
will check everything again over the weekend
Old 03-15-2007, 11:10 AM   #6
Chris07LB
Chris07LB's Avatar
Be sure to report back with what it was..
Old 03-15-2007, 03:44 PM   #7
den37
den37's Avatar
Drives: toyota vitz
went to another toyota agents they checked all fuse etc . could not find out why it does it ,said poss loose connection somewhere inthe main wire of the car : so the saga continues
My French Vitz RS Mister Kill Photo-Video-Media Gallery 21 08-03-2007 06:37 PM
JDM Vitz Parts!! MC-BPT Sponsors Classifieds Area 20 06-20-2007 03:44 PM
My Vitz RossP Photo-Video-Media Gallery 21 06-16-2007 03:30 PM
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 06:20 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
