Old 01-24-2012, 01:49 PM   #1
yarisyeti
Drives: 2011 Yaris 3d LB
Can I use a 529T?
yarisyeti is offline   Reply With Quote
Old 01-24-2012, 02:15 PM   #2
Originally Posted by yarisyeti View Post
Can I use a 529T?
Yes. The 529T just gives you one direction, whereas the 530T gives you both.
Old 01-25-2012, 01:07 PM   #3
yarisyeti
wouldn't hooking up a relay like thishttp://www.automotiverewire.com/Navagation/spdtrelayswindows.htm work just the same?
Old 01-25-2012, 01:17 PM   #4
Yes, although the relays will stay energized as long as the output channel is on, whereas the 529T or 530T has some intelligence to turn its relays off. The problem with leaving them energized is that if you trigger the output channel after turning the car off, and then leave the car parked for a day or so, you may come back to a dead battery.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
