Old 01-24-2012, 03:52 PM   #1
yarisgirl100
yarisgirl100's Avatar
Drives: 2009 Yaris
Send a message via Yahoo to yarisgirl100
I dont think iv been on here in atleast 2 years! lol Its good to be back! :)
yarisgirl100 is offline   Reply With Quote
Old 01-24-2012, 11:27 PM   #2
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
Texas cuties in the house
Everything arrived today for the install. I just got out of work, now I'm heading out to the garage (too bad it's 20 miles from my house, lol) with camera in hand. If everything goes smooth, I'd be interested in finding another Yaris in the area to do the install on for a YouTube video. But, I should probably set my sights a bit lower for tonight :)
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 01-25-2012, 10:40 AM   #3
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Mission Complete
I still need to aim them, but I might as well wait until my new bulbs arrive. I plan on applying a small ring of silicone epoxy around the bulb socket to hold them firmly in place...just in case.
I did take a couple of photos, but I just got home and haven't had a chance to check them out. Does YarisWorld have a picture archive that I may upload to, or must I use a third party like Flickr?
I would REALLY like to do this install on another Yaris. IF I get the chance, I'll attempt a full instructional with photos. For the time being, I'll atleast try to get a step-by-step write-up and compile links to all the YarisWorld resources that helped in the process.
HUGE THANKS to CTScott!!
Old 01-26-2012, 02:26 AM   #4
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
I'm about to start going through photos now. I'll start a new thread for them to avoid confusion and to preserve any useful information here
The rocker switch that I used has 3 prongs. I didn't wire up the 3rd prong for the diode (LED) yet. But, when I do I will connect it to the Illumination wire (aka: rheostat, dimmer...a function with many names..lol), correct? The main reason I didn't do this was because I had been up all night and didn't want to get the other 2 wires mixed up and cause some type of damage. I'm assuming Illumination is next to Ground, so that the diode can make connection and provide light when Illumination goes positve. That means that the wire to Pin 3 is on the other end of the 3 prongs, and the on/off disconnects it from the other 2. I'll try to post up a little picture of the wiring diagram, since my lack of an electrician's vocabulary is probably very confusing.
Old 01-26-2012, 08:12 AM   #5
If the switch is only a 3 terminal one then don't connect the illumination. For the way that the fog light circuit works the illumination and switching need to be separated. If you connect the illumination wire to the 3 terminal switch, you will then be bridging the fog light and illumination circuits, which you do not want to do.
The switch that I posted the link to above has the LED completely separate from the switch (i.e. There are 4 terminals - 2 for the switch and 2 for the LED). With that switch the switch contacts are part of the fog light circuit and the LED is a completely separate device on the illumination circuit.
Old 01-26-2012, 10:31 PM   #6
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Cool!! The fact that you had mentioned that was why I decided to leave it alone.
None of my pictures turned out very well. I re-read a few articles on nighttime automotive photography, and I'll give it another go tonight after I finsish polishing the car. Chris07LB would be proud, I'm finally using Turtle Wax Ice Polish
The 3500K bulbs I installed look really nice, but the lighting on a dry night is terrible compared to the untinted, white(ish) bulbs that the fog lights came with. Though, I'll save my criticism until I've had a chance to actually use them in the fog, and until I've confirmed that they're perfectly aimed. The amber should cut through the mist/fog better than white, due to the lack of the blue spectrum refracting off the moisture in the air. We shall see.
Fog Lights for 2007 Liftback razzorjet2 DIY / Maintenance / Service 1 04-04-2007 12:43 PM
Looking to add Cruise to my 2007 Liftback yaris Yaris_420 Performance Modifications 3 01-28-2007 06:46 AM
