Old 01-24-2012, 11:22 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by Deathegg View Post
Even if it weighed 50 lbs, it would have a negligible effect on...well, anything! I plan to do something like this soon, the road noise is bad on these cars. Thank God the engine is fairly quiet at speed.
Good job! I never thought of bed coating... It dries very hard then?
Not to burst your bubble, but you are incorrect. I can attest to that easily. 50lbs is 50lbs and will affect acceleration and braking. I see a very noticeable difference rolling on 15s as opposed to my 18s as well as whether or not I have my subwoofer box in the trunk or do not. Performing a spare tire delete even makes a difference. Every change you make to a car that is designed like the Yaris has an impact and you need to weigh the pros/cons. An example is going boosted and not only that, but whether or not you go SC or turbo when you gauge your FE. You very well trade FE for power.
Old 01-25-2012, 08:51 PM   #2
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
Wow, you must have a very sensitive backside if you notice the performance difference in 50 lbs. That's about 8 gallons of gas in the tank. If I take out the spare tire, my butt will not notice the difference. I would have to have a ScanGauge or similar instrumentation to tell the difference in MPG, acceleration, etc. Now, if you're talking about wheels and tires, that's a big difference in unsprung weight between 15" and 18". You'll notice that more than other weight reduction/increase.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 01-25-2012, 10:32 PM   #3
Viperoni
Drives: 2005 Toyota Echo
Completely correct, you're noticing the unsprung weight difference, which coutns 4-10 times more than regular weight.
I can just barely feel the difference when I pull my sub box + amp out... and it's pushing 90lbs.
CTScott, do you have any vids of your mufflerless exhaust? Just wondering how it sounds.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 01-25-2012, 10:34 PM   #4
It's actually the stock exhaust/muffler with a Toyota Thailand dual exhaust tip.
Old 01-25-2012, 10:37 PM   #5
Viperoni
I'm going to go ahead and delete my post, I just missed the forest for the trees lol.
Old 01-25-2012, 11:47 PM   #6
SAV912
Pirate Yaaaaris
SAV912's Avatar
Unsprung weight =/= dead weight. There will be a noticable difference on weight attached to parts of the car that directly handle the power vs weight somewhere else in the vehicle. That's why lighter wheels and tires are more noticable than removing the spare tire or a subwoofer.
But if you notice 50 lbs (which must be a hell of a hard hitting woofer), then more power to you. My butt dyno isn't that sensitive.
Scott, I'm thoroughly envious of your lift. And I may do the rubber brush on coating now. I've already done spray on bedliner and it made an appreciable difference, but I only did two coats on the wheel wells. I didn't do anything under the center of the car.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 02-07-2013, 04:22 PM   #7
nookandcrannycar
Performing a spare tire delete even makes a difference. .
Good to know. For everyday driving (unless going away on a trip), I'm going to remove mine. I have tire sealant and am paying extra for AAA plus coverage (longer free towing range). I've never needed either within my metro, but they'd be available if need be. Normally painless and transparent ways to increase MPG = all good in my book. I just thought (not based on more than a vague hunch really) removing it wouldn't make any difference. I trust your judgement. I don't think you would write this unless you had noticed a difference (even if it isn't much). Come to think of it, I can't remember the last time I had to put the spare to use in a car.
Old 02-07-2013, 04:53 PM   #8
nookandcrannycar
^^^^^ Oops . I just read your other posts (and other's posts) on this thread and realize the difference you are referring to = in performance not MPG. Amazingly faulty assumption on my part, especially since you are 'Mr. 143'. Re my Yaris, I am probably too clouded by MPG as a first thought.
Old 02-07-2013, 04:56 PM   #9
nookandcrannycar
^^^^^^^^^^^^^^^^^ Above (post #37 meant to appear below #36 but system posted to top of new page instead)
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Sound dampening rear hatch area? m911gt DIY / Maintenance / Service 28 10-10-2013 03:39 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Just ordered some sound dampening stuff Brad D General Yaris / Vitz Discussion 8 06-10-2009 08:09 PM
Any non-Dynamat sound dampening? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 12 11-18-2006 02:32 AM
