Old 01-25-2012, 02:15 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
if the 2zrfe bolts to the yaris transmission, it should make for an easier swap.
The 1.8L Matrix (1st gen?) has a C59 trans, which has pretty much identical mounting holes to the C50/C56. I've got one of each on a workbench at school that I can take pictures of at some point.
Old 03-04-2012, 10:07 PM   #2
2greek4u
Drives: 2008 5HB LE
I'm a new member on this Forum....but I have been forever on Newcelica.org( as "many"). I know the 2ZZ-GE inside and out. I know for a fact that the 1zz uses the C59 transmission and that one bolts up to the 2zz perfectly fine. So a 2ZZ swap wouldn't that hard...."IF" the C50/C56 has the same bolt pattern as the C59.
Of course there's the obvious engine supports that would need to be fabricated.
Bodywork modified/fortified(the subframe on the Yaris looks wimpy compared to the Celica).
You would need the Celica harness to be able to run the Power FC (Standalone) for the ecu.
The only hard part would be the axles fitting the hubs and finding a good 2ZZ with a C60 trans.
But is it worth.... it maybe not!.......but It does have "the" cool factor.
2greek4u is offline   Reply With Quote
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
