![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
Vitz (Yaris) advice needed pls
Hello, I'm new to this.
I recently got my Yaris 2007 post facelift model imported form Japan a week ago. Its known as a Vitz here. It has about 27,400 km on the clock with the auction report. I just have a few questions: 1. Do I need to change the engine oil / filter ? Currently the engine oil is somewhere in between the two holes on the dip stick, say about 1/2 inch below the top hole and a slightly darkish brown. 2. Should I replace the CVT transmission oil as I heard that its supposed to last a lifetime. There is also no dipstick to check the level of the CVT as in earlier models Why did Toyota do that????? ![]() Thanks in advance Tyrone |
Do you have an owners manual? What does it say to do? About the CVT oil? If so whatever it says do it.
Since the engine oil DOES have to be changed at intervals and you do not know when it was last changed (and the oil isnt full indicating its been some time since it was changed) go ahead and change it.
Thanks Bronsin,
The owner's manual I have is in japanese. It came with the car :s When does the engine oil indicator on the dash light up? I'm sure it would have by now if the oil was too low. Just asking. |
#4 | |
If its the service light (probably) it means its time to service the engine and you should change the oil. To turn the light off: With the engine running set the trip meter to ODO. Shut the engine off. Hold the button in you used to set the ODO. Start the engine while holding the button in. Light goes off after a few seconds. The light comes on every 6000 miles on mine. Which doesnt mean a thing unless the car has been serviced by the POs. Which of course you have no idea.
Thanks Bronsin,
Will check the dash for how many oil lights before switching on the engine. |
You should be able to get an english version of the OM on line. Then you can find out about when the CVT oil is changed.
I ran a machine at work once made in Japan. One day I pushed the wrong button and all the instructions on the CRT turned to Japanese! The company had to spend $5000 (the price of one days consultation) to get a service rep in to set it back to english!
#7 | |
![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
Oil level - it really depends on when you checked the level. If the car has been sitting, say, overnight than between the notches would mean low level because there is no oil in the engine and filter. The manual will probably say something along the line of checking it when you fill up, i.e. when the car has been recently ran and engine and filter has oil in it. When you find the manual, verify it just in case. Also, for most cars difference between the two marks on the dipstick is about a liter. You need to know that so you don't overfill when adding. On a Yaris however, this difference is more like 1.5 l (I am speaking of 1.5 gas engine). Again, the manual would have that info.
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
I have a Toyota Vitz RS japan import. My opinion is to do a general service on the engine break pads ... because you don't know when did dis Japanese guy did the last service.
Good luck With your Vitz Japanese the best :) |
![]() Drives: 2008 Yaris 3dh Black Join Date: Jan 2012
I'd do a tune up and routine maint. On it including brake service like mentioned above.... As for your transmission fluid, you will not need to service it as its a sealed transmission... The only reason the fluid would be changed is if there was a transmission service or it was replaced. Good luck
#10 | |
EDIT: ah, this is CVT...no idea about this one.
Thanks guys for all your replies.
I did an oil change and the oil was black. When i checked it this morning after the car sat overnight, the level was just a wee bit above the top notch. The few service manual pages that someone on this site recommended me to download says that that it shld be between the bottom and top notch ![]() If what Yuri says is true, then when is the best time to check the engine oil?????? |
#12 | |
Check the oil in the morning when the engine is cold and before starting it. You can also shut it off and wait 15 minutes in my experience.
Thanks boss for the clarification :)
I've tried searching the net but no luck. Where in the world can I download an english version of the Yaris 1kr-fe owner's manual????
Not quite a noob
If you're unsure about the oil.. change it now and start tracking it from this first change
![]() Drives: Yaris 2008 Join Date: Apr 2011
How to change CVT Transmission oil Yaris 2008.
Hi everyone,
I need to change the Transmission oil on my Yaris 2008. My car manual is in Japanese and i am unable to find the English version. Can someone give me step by step procedure for the same. Help is much appreciated. |
#17 | |
http://www.microimageonline.com/foru...T-Fluid-Change
| In need of advice on maintenance on my 2.5 yr old Yaris Sedan | Yari-Chan | DIY / Maintenance / Service | 29 | 07-02-2013 04:36 PM |
| Advice on long distant driving with a yaris | signs | General Yaris / Vitz Discussion | 34 | 03-18-2010 01:14 PM |
