Old 01-29-2012, 01:55 PM   #1
Geoff Peace
Drives: Yaris 1.33 litre 2011
Originally Posted by Dc1011 View Post
So the dealer figured out that the "miss" I was feeling at idle was failing spark plug in cylinder 2. So I purchased 4 NGK iridium plugs.
Can anyone give insight on replacing them dyi. Someone said something about adjusting gap?
Thanks!
Do not alter the gap it is preset. A very light copper grease on the threads, never mind the 'precoating'. screw in by hand they will screw in easily this is to prevent cross threading. They must be torqued correctly the plug manufacturers usually give the correct settings on their website. They will give a range, e.g. 15 - 20 lb.ft. Take the lower setting because the threads are greased. If you cannot find the torque post the plug reference number and I will tell you.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
spark plug change tools patm DIY / Maintenance / Service 1 10-17-2011 04:42 PM
Checking engine performance after spark plug change phantomlord DIY / Maintenance / Service 6 06-22-2011 04:38 PM
spark plug change yukonjack DIY / Maintenance / Service 12 12-02-2010 12:21 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
