Old 01-29-2012, 07:36 PM   #1
bribri
Drives: white stock yris
just got my car back from auto collision repair. $10,000 worth of damage. replaced front suspension (both sides) and rear axle. They put the 23mm sway bar back on. The car drives good but slightly resists turns. I asked the alignment shop to adjust toe to 0 degree and add as much negative camber as they could. By eyeing the front, it looks like 0 but the back has toe.I was thinking of shimming the rear. Front had toe out and rear was shimmed before the accident. I really love driving my yaris more then any other car I have owned. It handles and brakes so awesome. I might wait until spring before I tinker with toe (over steer you know)
Viperoni, how did you get a pinch if toe in the rear?
bribri is offline   Reply With Quote
Old 01-30-2012, 09:53 PM   #2
Viperoni
Drives: 2005 Toyota Echo
Scott @ can-alignment set it up like that, he used the proper alignment shims and got me just a hair of toe in (I think it's like 1/64th of an inch) and -1.5* camber.
Front is 0 toe and -1.5* camber too.
FWIW my next steps in the sprint will be to try to get the rear camber up to -2.5*, get the front camber more than it is now and add a bit of toe out.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 01-31-2012, 08:05 AM   #3
bribri
looks good. What is the charge for an alignment? Why do you want so much neg camber and toe out?
Old 02-01-2012, 12:59 AM   #4
Viperoni
On the track, I'm wearing the outer edges of the tires like madness. I can see in photos alone that I'm going into positive camber. On the street, not so much, but it's still noticeable even on my streets.
A little bit of toe out on the front helps turning into corners.
Old 02-06-2012, 11:39 AM   #5
bribri
adding a lot of negative camber will reduce your braking performance. It's too bad that a track set up is not so much fun to drive on a long road trip. Stiff springs and sway bar will help with body roll and the tires will run flatter in corners and straight line; better for braking. There will also be less front end dive which will allow you to use r compound tires without upsetting brake balance (front to rear). It's all a balancing act.
I put the 1.47mm shimes in and found that the back end felt too odd in a corner so i removed them. I might spend some time reduce the thickness to around 1.00mm and try them again.
What track to you go to and with which group? What mods have you done to your Yaris? Any brake upgrades?
Alignment question ? 90% street / 10% race annn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-25-2012 11:48 PM
Alignment Question gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-16-2009 10:35 AM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Lowered today on tein springs...pics and alignment question Brentorius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-27-2009 02:28 PM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 12:04 PM
