![]() Drives: 2010 Toyota Yaris Join Date: Jan 2012
Swaying Issue.....
Hey guys me again I have another questions for you guys, when ever I'm on the highway or going over 50 MPH my car sways sometimes I could be from left to right... Any ideas???
Heart Up! Vitz
rotate your tires?
hows the thread on your tires? lots of wind from big trucks passing you by? are you on stock springs? |
Heart Up! Vitz
It could be the treads on your tires. When i first lowered my car on new tires, i had to rotate the front right with the front left since it would pull my car slightly to the right.
Install a sway-bar in the rear and I promise the swaying from the trucks will lessen to where you will barely notice it. Thats all the possibilities that i know of. |
I agree, if you do not already have a "rear swaybar", install one before doing anything else.
It's absolutly the "best bank for the buck" as far as ride and handeling is concerned. You will be amaze on how stable the car wiil be with no "sway" or wandering. |
#6 | |
Do you know where I could get one?
Bad tires
Bad shocks Unbalanced wheels/tires Get a rear sway bar (purchase through Micro Image [PM Cali Yaris here] or try to find one used). |
Yes... get one from Micro Image. He is well known here. His Yaris sway bars are the most inexpensive and the quality is first rate.
I personally have a Micro Image sway bar and it's great! Here is the order page for the sway bars... http://shop.microimageonline.com/Bracing-Bars_c22.htm Here is a DIY on how to install it. It's actually quite simple. http://www.yarisworld.com/forums/showthread.php?t=14084 |
could also be just simply road crown.
Wider tires (aftermarket rims) and the sway bar stopped my highway wander permanently.
TRIM HUNTER
DITTO
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
+1 for the 19mm Micro Image sway bar.
Don't take it to a corporate shop to install. Go to some dirty street garage, because you'll need someone with a giant pryer bar to get off some suspension bolts. Should take 20 minutes and $30. |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
Heart Up! Vitz
DIY, you dont need a pry bar to install the sway bar.
I did it in my small one car garage by myself. Just need a torque wrench to torque bolts. |
For what it is worth, I threw a video together when I installed my sway bar. Not a good video job but shows how easy it is..anyone can do it...if i can.
http://www.youtube.com/watch?v=8RKn7vV4fIo |
Heart Up! Vitz
NICE! bairjo.
Good video. |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
Do you lose some clearance by installing the sway bar? Is it easy to tell you have a sway bar installed without really looking for it?
I commute 60 miles a day 5x week, so it might be nice to lose some of the highway wander I get. |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 12:01 AM |
| Issue for LP setting on 4 channel amp. | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 02-08-2010 12:10 PM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 04:10 AM |
