Old 01-30-2012, 09:23 PM   #1
Originally Posted by Ratz View Post
Thanks for your quick answer CTScott.
The reason I am asking is I like to install a temperature gauge in my Yaris.
Hooking up a scan tool to a DLC terminal and seeing engine temperature gave me an idea that I may use a temperature gauge compliant with CAN bus signal.
This way I can avoid inserting a temperature sensor in the radiator hose modification or fittings in the engine block and avoid running wiring from the engine compartment. Since I could just tap into DLC terminal wiring or instrument cluster wiring as signal wiring is available in both.
I guess I will send the manufacturer an email and see what they say about SAE J1987 protocol. Specifications state it is compatible with SAE J1939 data protocol.
Here is a link to the gauge I am considering as it has a nice large sweep. I could go with digital gauge but analog grabs ones eye attention faster.
http://www.vdo.com/generator/www/com...n_link_en.html
Any input is welcome.
I don't believe that gauge will work, as the SAE J1939 compliance is at the low level. The communication that allows a device to read PIDs, like the water temp fall under the high level ISO 15765-4 protocol.
Old 01-30-2012, 09:46 PM   #2
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Too bad, maybe one day everybody will get synchronized and use something like NMEA2000. I sent them an email already, to inquire if their gauge would work with SAE J1987 data protocol, now I am skeptical. Back to the drawing board.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
Rear Passenger Area Power Outlet DIY - Sedan fnkngrv DIY / Maintenance / Service 4 04-04-2019 07:03 AM
Group Buy for NTD 3Drive throttle controller twpanson Sponsors Classifieds Area 35 11-17-2009 10:18 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
