![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
alright here is my problem! when i disconnect the boomslang harness from the ecu the car runs fine! if i plug the boomslang into the ecu and put the bypass harness the car runs like shit .. rough reving and jumping idle problems!! so is there an issue with my boomslang harness or wat? then when i plug it into the aem fic .. it seems to run fine with only once their was power loss for a split second!! i dont think the boomslang works with the aem fic bypass it doesnt seem to work!
#2 | |
The boomslang should work fine with the bypass. With fnkngrv's boomslang I found that two wires on the male connector had broken loose from the pins. The male end uses a connector that is harvested from an ECM, so rather than having pins which are crimped to the wires, the wires are just soldered to the tabs that would go into the printed circuit board in the ECM. If any of the solder joints aren't perfect, they will pull off with vibration.
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 05:49 PM |
| Yari Boosted, Enge lite... | N3misiS | Forced Induction Forum | 14 | 11-20-2009 07:22 AM |
| Going Boosted | FryGuy | Forced Induction Forum | 53 | 03-01-2009 10:01 PM |
| PE Boosted Yaris Video | jinxor | Forced Induction Forum | 16 | 02-06-2009 02:33 AM |
