Old 02-01-2012, 09:33 AM   #1
Jack Yak
Drives: Yaris 1.3 07
Dirtiest engine bay ever. And 1.3?
:( i'm gonna clean it ,, but i did not do it before because someone told me that it's too bad if you cleaned your engine and you don't have to do it
and yes sir it's 1.3
Originally Posted by goliath1812 View Post
did you disconnect the negative from the battery to let the ECU reset?
yes i did
i disconnected it and reconnect after about 10 min ! NO change NO improvement !
Jack Yak is offline   Reply With Quote
Old 02-01-2012, 10:10 AM   #2
kou
Drives: 08 lb
Whoever told you not to clean your engine is a dumbass.
Old 02-01-2012, 11:49 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I thought in 07 the yaris sedan was only available in 1.5L
http://en.wikipedia.org/wiki/Toyota_Vitz
right...
Old 02-01-2012, 01:08 PM   #4
Jack Yak
right you are
Basicly what he was trying to tell you.
If you unscrew those 2 phillips and disconnect the sensor, you can pull it out. Then you can clean the little shiny part in the sensor that is shown in the picture attached. It usually gets dirty and is a good idea to clean it every now and then.. esp with a filter like you have there. Those filter doent filter out as well as the paper ones do, but thats for air flow reasons..
I would disconnect your battery again, and clean the MAF sensor. then put it back. Your ecu should reset your learned driving habbits.. You MAY feel a throttle response difference but unlikely. But it doesnt hurt to clean it.
you mean that i have to clean the shiny part in the sensor followed by disconnecting the battery ,, so that i MAY feel some improvement ,,, but you are not sure that i'll feel improvement in acceleration ? ? right ?
right...
No i have 07 yaris sedan with 1.3L engine
Old 02-01-2012, 02:25 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
you dont have to disconnect the battery to clean it.. but it would help..
disconnecting the battery will reset the ecu. the ecu learns driving habbits and compensates. being that you already disconnected it to begin with, you dont have to. unless u get a code.
Am I the only one about this thread
-Derrick-
Old 02-01-2012, 04:34 PM   #6
1.5
Form>Function
1.5's Avatar
Dude i am confused. And I still disagree on there being a 1.3 sedan in 07 unless its a CAD import.
Old 02-02-2012, 11:46 AM   #7
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
right. wash it.
yaris 2sz is offline   Reply With Quote
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
FS: AFE Air Intake System (Cold Air Intake) jjbG35yaris Items for Sale by private party 7 04-01-2011 02:58 PM
