Old 02-01-2012, 01:17 PM   #1
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
A new intake will probably only give an extra 1-2 hp over stock, which you probably wont even notice. It's never a bad idea though to clean your MAF. Especially with how dirty your engine bay is.
goliath1812 is offline   Reply With Quote
Old 02-01-2012, 01:39 PM   #2
Jack Yak
Drives: Yaris 1.3 07
you mean no increase in 0-100 acceleration "for example .. " occurs with installing new intake at all ? ?
guys : should i change the filter place ? or that's good place ?
i would like to move it slightly left and slightly down
Jack Yak is offline   Reply With Quote
Old 02-01-2012, 04:35 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Is this why you are so graciously giving yours to me? lol
Old 02-01-2012, 04:50 PM   #4
Jack Yak
Dude i am confused. And I still disagree on there being a 1.3 sedan in 07 unless its a CAD import.
it's middle east version dude ... in middle east the 1.5L engine only with 2010 , 2011 , 2012 ! before 2010 all yaris in middle east with 1.3L engine
you dont have to disconnect the battery to clean it.. but it would help..
disconnecting the battery will reset the ecu. the ecu learns driving habbits and compensates. being that you already disconnected it to begin with, you dont have to. unless u get a code.
Am I the only one about this thread
A Code ! ! ! wat do you mean by get a code ? ?
Old 02-02-2012, 09:52 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
A code is when your check engine light comes on. It will have a code set in the ecu. You can use a scanner to read what the code is. Either the scanner can erase the code, OR you can just disconnect the battery for a min and it will erase the code also. SOMETIMES people get a code when doing an aftermarket Intake. Like if you forgot to plug the connector back into the MAF sensor and turn the car on, like i did..
-Derrick-
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
FS: AFE Air Intake System (Cold Air Intake) jjbG35yaris Items for Sale by private party 7 04-01-2011 02:58 PM
