Old 02-01-2012, 04:36 PM   #1
diablo7772
Drives: VVTI 1.0 W reg
Just took of the maf and had a go in the car it has helped the problem a lot but it has put it in limp mode so limited to 3.3k revs.
I will take it off and just dry it :) see if that helps unless the WD has damaged it.
diablo7772 is offline   Reply With Quote
Old 02-01-2012, 04:39 PM   #2
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
WD40 is a lubricant...it will stay in the wires forever unless you clean it off. Spray it with some electronic cleaner (or a specialized MAF cleaning spray). Some people use a non-residue carb cleaner, but many say it's too aggressive.
I suppose alcohol would work too.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
V Reg 1999 Toyota Yaris 1.0 gls semi auto jshakey UK 1 03-08-2012 03:00 PM
Slow cranking on an 02 1.0 vvti Yaris Duberry UK 0 11-01-2010 09:20 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 12:15 PM
x reg yaris 1.0 vvti gs (feeler) hula hoop Cars for Sale by private party 0 12-04-2008 06:36 AM
