Old 02-04-2012, 03:37 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i can tell you once you get stuck even the slightest you won't be able to pull yourself out, this is the only thing i don't like about the yaris. i was stuck in sand once and snow once, but only one wheel from the front spins when i give it gas, the other wheel just stays motionless! if both wheels spin together I'm sure the yari would be able to pull himself out
caineroad is offline   Reply With Quote
Old 02-05-2012, 10:45 PM   #2
Idahotom
Drives: 2008 5 sp. LB
I live on a dirt road that gets mushy, icey etc. The Yaris is no better or worse then any other rig I've had. I certainly don't baby it, hell, it's a Toyota! Tires are the key, though nothing special, just good as I would have any other rig I drive on the same road. The low ground clearance, in deep snow, is an obvious problem, but that's why I have the '89 All-Trac!
The only negative is the back window gets really dirty quick, due to the aerodynamics. I don't care about that, that why I have side mirrors. Call it privacy glass.......
Idahotom is offline   Reply With Quote
Old 02-10-2012, 05:55 PM   #3
joe keeney
Drives: yaris 2 door hatch
little car that can
try family dollar 7 pound bag of cat litter only a dollar makes for great traction.
joe keeney is offline   Reply With Quote
Old 02-11-2012, 07:55 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that won't help. The Yaris has an open diff, buying a LSD would help that, but those are expensive.
Colin Chapman disciple
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Dirt Road Yaris carlghoul Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-16-2011 06:22 PM
