Old 02-08-2012, 01:35 AM   #1
SineWave
Drives: Gen3 Yaris ZR Manual
Forgot photos.
SineWave is offline   Reply With Quote
Old 02-08-2012, 02:09 AM   #2
JayGee
Drives: 2012 Yaris XR 3DR
Originally Posted by SineWave View Post
Forgot photos.
Thank you very much for the photos. They are a great help.
From the pictures, it looks like a camera with a mounting similar to this one might work.
http://www.ebay.com/itm/TOYOTA-Crown...item27c221981a
I'll investigate a bit further this weekend.
JayGee is offline   Reply With Quote
Old 01-21-2015, 03:58 PM   #3
coolcolger
Drives: Streak Blue 2015 Yaris SE
Forgot photos.
I know this is an old thread but I have the correct OEM camera for the rear hatch... The black "block off plate" insert thing that has the two bolts holding it in place that is clearly shown in SineWave's picture: how the heck do I get that off? The nuts that are attached to the bolts when turned cause the bolts themselves to turn as well. What am I missing here?
coolcolger is offline   Reply With Quote
Old 01-21-2015, 09:59 PM   #4
From his photos it looks like you can either insert an allen wrench into the end of the bolt, or hold it with a tiny socket to then let you loosen the nut.
Old 07-15-2015, 09:42 AM   #5
OGHUGO
Drives: 2015 Yaris 5 Door Hatchback
There is no hole in the end of the screw, yes perhaps a tiny socket or even a pair of grip pliers will do but I only had a long socket with a rachet, so the screw was covered completely.
Anyhow I managed to take it off and just need some glue to add on the screws when I put it back in place so that the bolts do not spin as I tighten up the nut.
OGHUGO is offline   Reply With Quote
Old 07-15-2015, 09:58 AM   #6
OGHUGO
Also, tried to post a link for an after market camera but seems that my post have been deleted?? Don't know if im not supposed to link to ebay sellers but I see other people have done it so.
Anyhow I found a camera that may be a direct fit for this and I have been in contact with the seller I have sent him pics and measurements of the cover and he said that the one I ordered should fit. I should receive it next week I will let you guys know if it fit.
On that same note, is there a harness that I can use for a stock radio for the 2015 Yaris LE?
Thanks.
Old 07-15-2015, 06:04 AM   #7
OGHUGO
Had the same issue here they unscrew from the plastic piece of the cover. I had to remove the plastic piece very carefully and got it off but it was a pain in the butt. Also once you are about to put it back on you have to add the screws to the plastic piece and then add it to the back door. I have not done that as I want to add some jb wells glue or something to the screws so this will not happen again when/if I ever unscrew them.
cheap car, cheap parts, cheap it is cheap it does (stupid is, stupid does)
Let me know if you guys have had any issues removing this thing.
Also have found this camera that may just bold on to this car..
http://www.ebay.com/itm/171593317287...%3AMEBIDX%3AIT
been in touch with the seller and have provided pics and measurements of the black part that is on the car and he says this may fit. I have ordered it and should get it next week. I will let you guys know if it fits..
On that same note is there a harness that I can add an aftermarket cam to the stock head unit? I have the AXCP-Q15U (T10028) unit. Let me know, thanks.
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
