Old 02-08-2012, 01:10 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
still cant figure out how toyota manage to disable my a/c system after they replaced the water pump.. a/c not turning on , fuse is ok but seems like im not getting power to the a/c compressor..go figure..
Old 02-08-2012, 01:32 PM   #2
Check to see if they plugged the connector back into the compressor.
Old 02-08-2012, 01:42 PM   #3
marcus
toyota
marcus's Avatar
yes they did..already rechecked it also checked fuse which was good still got light on the ac button..compressor click if i ran power directly from the battery so im at lost on what i am missing..too cold to fix right now waiting for a warmer weather..
Old 02-08-2012, 01:46 PM   #4
The AC ECU won't activate the solenoid for the compressor if there is an issue with the pressure (too high or too low), so there is probably a good chance that they nicked or flexed one of the aluminum tubes enough to cause the system to vent.
Old 02-08-2012, 02:05 PM   #5
marcus
toyota
marcus's Avatar
oh yeah i also check that as well toyota said its full but cant get pressure since i cant get the compressor to work..
Old 02-08-2012, 02:15 PM   #6
If they plug the TechStream tool into the car, the AC ECU will tell them why it isn't happy.
Old 02-08-2012, 02:17 PM   #7
marcus
toyota
marcus's Avatar
thats what needs to be done but they gonna charge me just for them to do that although i have a friend that works there i just have to have him take my car for a day.. thanks scott.
Has anyone had their Water Pump replaced? Carrot Top DIY / Maintenance / Service 48 03-20-2017 01:32 AM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Water Pump gave up on me finally Vioz DIY / Maintenance / Service 4 07-31-2011 06:08 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
