![]() Drives: 2010 Toyota Yaris 1.5L, 4D Join Date: Dec 2011
new brakes or some bs upsell?
i went to get some maintenance done and the people said that I needed new brakes, it is common for this car to need new brakes? It's a 2010 yaris (auto) with only 16000 miles on it! When I bought this car it already had 5,000 something miles on it.
I might go to the dealer or another shop later on this week to get a second opinion but I am kind of surprised since i thought brakes were supposed to last at least 25,000 to 30,000 miles. I don't drive with both feet ("riding the brakes") and I mostly use it to commute about 7-10 miles (14-20 miles total) each day. Mostly highway too, maybe like 1-2 miles is driven in the city. |
Gotta be BS. Factory brakes should get you 60k plus.
60k! Wow is that how much you drove before you replaced them or just a consensus?
In the off chance that I do need new brakes, do you think that Toyota would honor their warranty to replace the brakes? Given the high discrepancy between the consensus and my situation, it would be logical to say that new brakes would be covered by Toyota. Last edited by scene; 02-08-2012 at 03:59 PM. |
DAT'S RIGHT I GOTz 2
how much brakes was left?
new one are usually 10mm thick if they were between 1-2 mm then yupper they ready to change
The odds are you are dealing with a total scumbag. My wife couldnt wear out a set of front brake pads that fast.
#7 | |
thanks yarisworld for your input! I will take my car to the dealership some time next week (or month) since it doesn't seem to be a pressing issue to confirm the diagnosis or lacktherof. |
I have 25K on my 2009 and a couple of weekends ago, while I had it up on the lift with the tires off, I checked my brake pads and they had barely any wear at all.
toyota
i got 91000 km on it on the original brake pads just hitting half not even..i can probably do 3 more years..it is a manual ..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
manuals use infinitely less pad than autos. I went for a drive the other day and I could touch my rotors- they weren't even hot
#11 | |
Unless the previous owner stood on those brakes 24x7 I doubt they need replacing. I think the worst case I ever read about on here was at 15K but the driver admitted to being a brake abuser. |
mine is a 2010 also, i got 28k miles on my car. still have at least 50% on my factory pads..
oh did i mention I autocross once a month since I got it?
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
2010 with 60000km and rear pads have 3mm left
#14 |
went to toyota to check the brakes and they are at 8mm front, 5 mm rear
lol @ some people! |
#15 |
Just a heads up about the dealers. They can be crooks too! An honest one is a godsend.My daughters 98 Camry was making a lot of noise. The exhaust manifold was cracked. She took it to a dealer and was told she needed $3200 of work including water pump, radiator, head gasket (as well as the manifold.
My brother in law did the work for $800.
#16 |
since the yaris is front wheel drive how come the brakes in the rear are more worn down than the front? Are the rear brakes less thick than the front? yea i was really skeptical of taking my car to the dealership at first but my dealership is really good at taking care of their customers except for that fact they can get really busy (1-2 hour expected wait for simple jobs!).
When I was in an accident a few years ago with another car, we got a quote from them as a baseline and used that to compare with other shops. The quote we got from toyota matched the shops in my area with the exception of a couple of shops beating toyota by margins. |
#17 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
The rear star wheel adjusters may stop working after a while, leaving the rear brake shoes too wide a gap to brake first and strong. So they wear less than the front brakes.
I'm at 97k and haven't *needed* to change the pads/shoes, but keep adjusting the rear star wheel adjuster to keep it tight. Manual. |
#18 |
![]() ![]() ![]() Drives: 2008 5 Door Liftback Auto Join Date: Oct 2011
Auto or not 16k is way too short of a life. But if several people say it's the case it makes you think. Easy enough to take the wheel off and measure the pad thickness though.
1999 Honda Prelude Base 5 speed (summer driver) 2008 5 Door Liftback Auto |
| general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 03:20 PM |
| Rear Drum brakes | bankrobber | DIY / Maintenance / Service | 0 | 04-18-2010 12:39 AM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 01:04 AM |
