Old 02-10-2012, 07:11 AM   #1
CB900F2
Drives: 08 Sedan
Where you able to install the unit with out removing the steering wheel?
Originally Posted by Billiam View Post
Yes, it's about the same length...just a tiny bit longer to allow for the adjusting ring for the variable int part.
I think retail is about $150. I paid $115.
Old 02-10-2012, 05:59 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
The steering wheel does not have to be removed for this install. You'll remove 3 screws...one under the steering column and one on each side, behind the wheel (you'll have to turn the wheel to access these) to separate and remove the steering column cover. You then disconnect the 2 connections on the bottom of the switch, push in the tab that holds the switch in place and pull it out. Reverse the order to install the new switch.
If you want to enjoy your car, stay off of the internet.
Yaris Sedan Discontinued? green-phoenix General Yaris / Vitz Discussion 65 09-18-2010 12:52 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
