View Poll Results: Intake Question
I have an intake and + Mileage 8 47.06%
I have an intake and noticed a - Mileage 2 11.76%
I don't have an intake 7 41.18%
Other (Please post why) 0 0%
Voters: 17. You may not vote on this poll
Old 02-10-2012, 04:10 PM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Then I got a gain of 15 whp from a pulley, header and axle-back exhaust. Went from 92 to 108 whp.
You're saying the intake contributed nothing to that change in numbers, as measured on the same dyno, with reasonably close ambient temp and humidity? c'mon guys.
This argument just won't die. A well designed intake that lowers intake temps and increases flow makes some power; maybe not a lot -- but some.
And mods add to each other's increases -- I believe ilikerice has agreed to this in other threads. (but maybe it's my wishful thinking)
/rant
Exactly! Even if it is slightly more free flowing + colder air it is going to increase performance over stock. Even if it is only a few hp, in our tiny engines a few hp goes a long way.
And although the afe is not a legit CAI it does still help with responsiveness and midrange power.
Old 02-10-2012, 04:46 PM   #2
RedRide
RedRide's Avatar
If that is true, there should be a spectacular difference in performace between suimmr and winter temps.
Yes, there is some slight difference between drivng in 90 degree temps vs sub freezing temps. However, the diffence in intake temps (stock vs CAI) is insignificant as far as this is concerned.
"A few HP gain" just because you lowered the intake temps a few degrees? I don't think so.
Like I said.... when a car is moving all intakes are fed cooler air!
When a car is not moving, which intake do you think would be fed the coolest air..... A short ram the has its intake next to/ on top of the engine or, a stock air box that his its intake right bebind the grill?
Old 02-10-2012, 05:22 PM   #3
1.5
Form>Function
1.5's Avatar
There is absolutely a difference between cold days and warm. I can definately notice a difference.
And a CAI would move the coldest air into the intake manifold at a stop.
Tags
air intake
Cold Air Intake... I PHANT0M I Performance Modifications 17 05-17-2012 08:57 PM
OEM Air Intake System bad Items for Sale by private party 2 04-04-2012 10:03 PM
Cold Air Intake... I PHANT0M I General Yaris / Vitz Discussion 2 01-31-2012 02:22 PM
Armchair theory - extreme cold air intake. Beer Jammer Performance Modifications 40 08-17-2010 02:00 AM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
