If you look under the dash on the driver's side, just above the fuse panel there should be an 8 pin connector (two pins on one row and 6 pins on the other). If it is there, then you can add the rear fog light switch, but you would also need the add the front fog light switch and relay, since it is driven by that. Or, you could add your own switch to supply 12 Volts to the light blue wire with the white stripe in pin 1 of the connector.
| Hi new here with a fog light question | jazzy yaris | Cosmetic Modifications (Exterior/Interior) | 5 | 03-23-2010 09:04 PM |
| Fog Light Install - HELP | GrimlockGT | Cosmetic Modifications (Exterior/Interior) | 1 | 03-19-2010 04:58 PM |
| '09 Fog light replacement | Mavix | Cosmetic Modifications (Exterior/Interior) | 5 | 10-07-2009 03:21 AM |
| OEM fog light switch question | kustom play | Cosmetic Modifications (Exterior/Interior) | 10 | 01-02-2009 06:33 PM |
