Old 02-19-2012, 06:21 PM   #1
Originally Posted by 09sedan View Post
have 2 questions for CtScott the almighty yaris guru:
i have a november 2008 built 2009 yaris sedan (Canadian market)
1. if i use the 2 switch setup, and i turn it on and have to brake will the CC automatically deactivate?
2. how do you tap into the cables on the connector from the on/off switch?
Yes the brake overrides CC.
If yours has the wiring from the ECM to the steering column, then you can use splice tap connectors (available from most auto parts stores) to connect to the existing wires. Your Canadian sedan may not have the wiring from the ECM to the steering column, and if that is the case you would need to add the ECM pin.
This thread has a DIY with more details:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 02-19-2012, 07:41 PM   #2
09sedan
Drives: 2009 yaris sedan
ok cool thanks for the info!, so D3 connector is left side of the yellow connector ? and if there is a blue wire there, then i can just tap into it, if not i have to run a wire through the firewall to the ecm?
09sedan is offline   Reply With Quote
Old 02-19-2012, 08:23 PM   #3
Correct on both.
Old 02-19-2012, 09:32 PM   #4
09sedan
great news, i just checked and i have all 3 wires, and my dash cluster has the set and CC indicators.
do i have to use the switches you mentioned, or can i use a plain SPST Normally open pushbutton that i can buy from my local electronics store?
Old 02-19-2012, 09:52 PM   #5
Any normally open switches are fine.
Old 02-20-2012, 10:17 PM   #6
09sedan
people are telling me if i dont use the expensive "aftermarket cruise control kit" which is like 3-500$ with installation that the CC might not disengage or the insurance company wont cover if something happens cuz its a DIY modification , are there any risks involved in using this mod? also i got a single 620ohm 1% 1/2Watt resistor, (im using 2 switch method) is that enough?
Old 02-20-2012, 10:22 PM   #7
Cruise control is a function of the ECM. You are just enabling that existing functionality by adding the switches and resistors as an input the ECM. The only way it can "not disengage" is if the ECM fails.
The aftermarket Rostra kit was actually recalled, because it has an issue where RF noise can make it misbehave, so I'd stick with enabling the OEM functionality.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
