My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
So I just checked the fluid and its light pink and smells like chemicals... no burnt smell.
I cant tell if the fluid is low, because on the dip stick it says Warm/Cold and not High or Low. Where should the fluid level be on the dipstick for it to be considered normal? |
#2 | |
INSPECT AUTOMATIC TRANSAXLE FLUID Drive the vehicle until the engine and transaxle are at normal operating temperature. Fluid temperature: 70 to 80 °C (158 to 176 °F) (a) Park the vehicle on a level surface and engage the parking brake. (b) With the engine idling and the brake pedal depressed, shift the shift lever into all positions from P to L, and then return it to the P position. (c) Pull out the oil level gauge and wipe it clean. (d) Push it fully back into the pipe. (e) Pull it out and check that the fluid level is within the HOT range. AT Fluid Level.jpg
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
Is it checked with the car idling?
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
Transmission service at 22K? Say thanks for the antifreeze and don't go back to that shop. If you really have transmission sluggishness (or whatever), to back to a dealership and keep complaining. Do you have a 2nd dealership close by?
So I just checked the dipstick after driving 10 miles and with the engine running and the transmission fluid is on the first notch up from the bottom. Which means its really low.
This could be why the car isint shifting in the best manner. Now, is it better for me to take it to the dealership so its on record, or put more in myself? |
#7 | |
Considering that they wanted to sell you more services for the tranny, I would make them do it with you standing right there.
So I took it to the dealership today, and the mechanic pulled out the dipstick and claimed the level was fine. I explained to him that this other shop told me my transmission was wearing and he looked at me like I was crazy. So lesson learned; do not bring my car to that quick lube place again. All they were looking for was more money.
| Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? | lejulie | DIY / Maintenance / Service | 14 | 10-23-2011 07:43 PM |
| Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment | lejulie | DIY / Maintenance / Service | 10 | 10-23-2011 07:35 PM |
| Installing a external in line transmission filter. | YarisSedan | Performance Modifications | 1 | 03-31-2009 08:03 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
