Old 03-15-2007, 04:20 PM   #11
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
10.75:1 at worst, 11.5:1 66% of the powerband.
9.5 was a hypothetical.
2000-5000 RPM: about 11.5:1 AFR
5000-5800 RPM: descends to 10.75:1
5800 on: stays around 10.75:1, horsepower flattens out, torque decreases 10%.
Taking AFR through through the tailpipe on a dyno through OEM cats will give you invlalid results. You need a wideband with a bung installed pre cat.
Your mileage will improve after a tune. That is if you aren't flooring it more than you were to begin with.
If you are gonna get a PnP done free by a reputable shop in your area, yes It may be worth it. If some toolbox shop does it, it will most likely do more harm than good. I wouldn't pay to have it done to this motor. The funds are better spent elsewhere, either an engine swap, or a turbo\supercharger.
I used to work at a shop porting cylinder heads for many championship race teams in various forms of racing, so I know all the processes and methodologies pretty well. Moose is correct, although I doubt you would see 15 Hp on this particular engine without cams or other component upgrades.
What type of head unit with AUX port? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 3 11-06-2006 10:21 AM
ODB-II port location? eTiMaGo DIY / Maintenance / Service 6 09-24-2006 12:27 PM
Port A Walls tomjasz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 09-04-2006 04:20 PM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
