![]() Drives: 2007 Yaris Hatch Join Date: May 2010
You hinted this is a "third" shop you've taken it to, any previous history with this place? Tin Foil hat on, maybe they removed the wrong drain plug, and started to drain the transmission fluid? I have 128K on my '07 auto, and I checked the level after getting home. I'm just below the first tic mark for hot on the picture on page one.
Related-ish story; My best friend bought his first new vehicle back when we graduated college, a 2001 Jeep Cherokee. Come time for his first oil change...and he doesn't pay attention or read the manual, on which drain plug is which. I got the call to take him up to Autozone to get more transmission fluid. I've been doing my own maintenance on my cars for over 10 years now, because I don't trust anyone else to touch my cars. Check the under side of your car too, and see if the drain plug for your transmission fluid looks like it's been tweaked. Or if it's "too clean" like someone wiped it off. Just a guess at why'd you have such a low level. |
#2 | |
I did that once, with the first oil change on my Subaru. I remove the drain plug, catch the smell and color of the fluid flowing, and head off with the other car to pick up some ATF.
| Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? | lejulie | DIY / Maintenance / Service | 14 | 10-23-2011 08:43 PM |
| Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment | lejulie | DIY / Maintenance / Service | 10 | 10-23-2011 08:35 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Installing a external in line transmission filter. | YarisSedan | Performance Modifications | 1 | 03-31-2009 09:03 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
