Old 02-24-2012, 11:14 PM   #1
Originally Posted by lantis View Post
Hello!
I have 2008 Toyota Yaris Terra A/C - sadly without power locks and windows:
http://www.toyodiy.com
I am considering of buying used power window and lock parts and installing those in my car (only front power windows, and at least front power locks).
I must replace door parts with door wires which leads to GD1,GD2 (drivers side) and FD1, FD2 (pass. side) connectors. From these connectors wires go to ECU (I don't have that wires mounted).
SOL version of Yaris according to:
http://www.toyodiy.com/parts/p_E_200...MGKW_8404.html
which has fabric mounted wireless locks (information from distributor's leaflet) and power windows has a same ECU like mine.
Is it possible do install original parts, connect these to ECU and have power windows and locks?
The ECM doesn't control the door locks, the Body ECU does (which lives within the under dash fuse panel), but that is the same between the Terra and the SOL as well, so it should work.
Old 02-25-2012, 05:50 AM   #2
lantis
Drives: Toyota Yaris II
That's good news. Thanks.
What is the part number of my Body ECU? I can't find this element in catalog's drawings.
It is hard to get to the Body ECU connector D33?
lantis is offline   Reply With Quote
Power windows and locks on a 2009 3dr. chilly79 DIY / Maintenance / Service 8 12-15-2010 01:55 PM
