Old 02-28-2012, 11:31 PM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
You might want to take a closer look. The automatic has a dipstick. As for the changing interval - This seems to get discussed at least weekly here.
The Japanese version that I have does not have a dip stick so there is no way of really checking the ATF fluid condition for me
Does anyone have any idea why the Japs would put a dip stick on one model of a particular locatoin and not the other????
tyrone_yaris is offline   Reply With Quote
Old 02-28-2012, 11:44 PM   #2
That's because you have the K41 CVT, which is completely different than the U340 automatic.
Old 02-28-2012, 11:53 PM   #3
tyrone_yaris
Oh i see. Do you know where I can get some info on drain / refill intervals for this transmission as the manual I have is in Japanese
Also if a DIY guide to do it is available on the net. Tried google but so far nothing.
Old 02-29-2012, 06:54 AM   #4
Here is a DIY for your CVT:
http://www.microimageonline.com/foru...T-Fluid-Change
Old 02-29-2012, 07:01 AM   #5
tyrone_yaris
Thanks CT Scott.
In the 4th point - I cant actually make out the location of the CVT refill hole.
In the 5th point - why do you have to let the oil drain till it slows to a slow drip?
Thanks
Old 02-29-2012, 09:24 AM   #6
Thanks CT Scott.
Thanks
I don't have photo of the location of the filler hole, but from this larger diagram you can see two round areas on the end opposite where the transmission meets the engine. The plug is located on the right side of the lower round area. It is a larger head bolt then the others around it and is has a thin gasket visible around its edges.
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
