Old 02-29-2012, 07:01 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Thanks CT Scott.
In the 4th point - I cant actually make out the location of the CVT refill hole.
In the 5th point - why do you have to let the oil drain till it slows to a slow drip?
Thanks
tyrone_yaris is offline   Reply With Quote
Old 02-29-2012, 09:24 AM   #2
Originally Posted by tyrone_yaris View Post
Thanks CT Scott.
Thanks
I don't have photo of the location of the filler hole, but from this larger diagram you can see two round areas on the end opposite where the transmission meets the engine. The plug is located on the right side of the lower round area. It is a larger head bolt then the others around it and is has a thin gasket visible around its edges.
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
