Old 03-02-2012, 10:39 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
the offset change is going to push the wheel closer to the fender and the outside of the car. This wheel choice is not going to require any modification to work so no negative effects like rubbing should occur. The wider wheel and lower offset is going to widen the stance resulting in improved performance and handling. Hopefully the wheels are lighter than stock also improving performance.
Old 03-03-2012, 06:36 PM   #2
33OH
Drives: '08 Yaris
What he said, 15x6.5 +38 will work perfectly. Btw - welcome, I'm from NEO as well. :)
would 16x8 with +25 offset fit on the rear? marcus Cosmetic Modifications (Exterior/Interior) 15 09-15-2009 03:43 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Will a 15x6.5, ET40 with 195/50/15's fit? schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-12-2009 08:30 AM
Offset 42 -> will it fit? Homeboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-24-2008 04:39 AM
