#19 |
I haven't seen the airbag connectors on the 2011 TC yet, to know if it is a direct bolt on and plug and play.
#20 |
I need more stars
Drives: Liftback Join Date: Jun 2009
How about the older tC models?
#21 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
If I got my hands on the tc airbag cover, could I possibly swap it with the yaris airbag cover? In other words, could I use the tc steering wheel and airbag cover but use the yaris airbag? Or would I need the tc airbag and cover? I just don't like the idea of the yaris cover not fitting the tc wheel perfectly (bad case of OCD I guess).
#22 |
The older TC ones have the same connector, and from a quick search it looks like the 2011 does as well.
As for swapping guts under the cover, there's a thread on here where I show what is involved in doing so. I took apart a popped one, which has none of the danger associated with doing so with a live one.
#23 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Does anyone know if japanese steering wheel will fit the 2009 liftback (Canadian version)?
Thanks http://injapan.ru/auction/x208512722.html |
#24 | |
#25 |
#26 |
You would have to transfer the airbag squib assembly over, since the cover is completely different. It would fit, but moving it over would be very difficult and dangerous.
#27 |
Thank you!
#28 |
#29 | |
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
![]() I just cut a piece of hard rubber, lifted the bottom spoke leather cover of the TC steering wheel and glued it in. I then glued the leather onto the hard rubber. I could have done a better job fitting it with my airbag, but I got lazy and eyeballed it. Looks like the spoke is now touching the airbag, but there's a small gap. |
#30 | |
Is the leather glued to the plastic underneath ? Was is easy to lift the leather cover? (Considering couple ideas) |
#31 | |
There's just not too much leather there to begin with on that steering wheel spoke, so I tried to straighten out the gap. If you were to do some fitting beforehand, you can get it to look lots better than I did. Good luck. |
#32 | |
I was considering removing the leather and working on the wheel underneath and then reupholstering.. another option is buying some leather and simple tools and upholstering the steering wheel that I have in my car from scratch.. I saw coupld such projects .. looks doable (it is not in English but pics are self-explanatory.. the guy is using some crappy leather but still gets a decent result) http://avtoperedelka.ucoz.ru/publ/tj...kami/7-1-0-142 |
#33 | |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
#34 |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
