Old 08-02-2011, 08:49 PM   #37
IVAN_TRD
Drives: YARIS
in puerto rico, we use prius pistons
IVAN_TRD is offline   Reply With Quote
Old 08-04-2011, 11:39 AM   #38
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
To build high performance Yaris motors?
Old 08-06-2011, 01:56 AM   #39
IVAN_TRD
Drives: YARIS
yaris and echo
Old 08-06-2011, 12:35 PM   #40
^ I keep seeing posts like this, and never a picture or a dyno. I believe you -- but it would be real nice to see how it's done and what the result is.
Old 09-17-2011, 01:58 AM   #41
Maitre_Te_Te
Drives: Yaris 08
X2... I want to see this on video and dyno run! Do you have this?
If I find a cheaper engine, I will try this mod.
Maitre_Te_Te is offline   Reply With Quote
Old 09-21-2011, 05:06 PM   #42
Maitre_Te_Te
Drives: Yaris 08
I can have an engine for 150$. If I put prius piston, I think that I need a tuning. FIC or camcon ?
http://shop.microimageonline.com/AEM...er-30-1910.htm
http://shop.microimageonline.com/Cam...t-i-CC-111.htm
Old 09-21-2011, 05:29 PM   #43
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
j'imagine.. lol (Sorry, nonconstructive post but this was funny)
Old 09-21-2011, 05:33 PM   #44
Maitre_Te_Te
Drives: Yaris 08
loll.. I have correct it :P
Old 02-18-2012, 05:10 PM   #45
10 Francis
Drives: 2010 Yaris S HB
Personally, I would be more interested in the Prius intake cam than Prius pistons. The effective compression ratio on the Prius changes due to VVT-i, but I've been told by experienced techs that it's around 6.5-7.5:1, depending on valve timing. The interesting thing to me would be a Prius intake cam and a supercharger- turn the Yaris engine into a Miller-cycle engine.
10 Francis is offline   Reply With Quote
Old 03-06-2012, 06:54 PM   #46
2greek4u
Drives: 2008 5HB LE
On every Forum too... but they never show anything it's like a secret voodoo cult!
2greek4u is offline   Reply With Quote
Old 04-15-2012, 02:50 PM   #47
spin_king
Drives: 03' 1.5 vitz rs
i wanted to raise my compression but couldnt find any for my vitz rs. i would like to know how if anyone has tried the 13:1 compression. what year prius pistons were used & if any addition fabrication work had to be done.
spin_king is offline   Reply With Quote
Old 04-15-2012, 04:26 PM   #48
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
oh yes I like the voodoo as long as i can see it doo its voo. until then it is like the sneaking myth of the 1k hp streetable hatch back that hunt down and devours v-8s.
and the getting another engine and building a n/a to do autocross would be a sweet project, i'm trying to get my pops in on a project with me but he is hesitant to do anything.
Old 04-15-2012, 07:19 PM   #49
We can get new higher comp pistons, just sold some to a customer doing an NA build.
Sourcing Prius pistons are cheaper obviously IF they work.
Old 04-16-2012, 01:36 AM   #50
mr_miles
Drives: 2013 Yaris
Wish i had a spare engine...I'd tear it down and find out.
Old 04-23-2012, 11:42 PM   #51
Nanoss22
Drives: Yaris sedan 10 std...
Guys here in puerto rico i have seen 2 hb with the prius piston mood and it work they fit perfectly no mood needed just replace the stock ones with the prius piston and the roods are the same original that came with the engine 1nzfe .....only the pistons.. Prius 2004 2006... I have allready the piston all assembled waiting for the mechanic...
Nanoss22 is offline   Reply With Quote
Old 04-23-2012, 11:48 PM   #52
Nanoss22
I need a repair manual for the 1nz fe engine so i can get all the timing all the screw torque if u know i will apreciated
Old 04-24-2012, 05:45 PM   #53
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
in the diy section:2007 Repair Manual.
And we'd love to see some build pics and a dyno run if you do it after too.
Thank you!
Would be so cool if it worked.
Colin Chapman disciple
Old 04-24-2012, 05:55 PM   #54
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
finally someone with proof of actually doing this.
2010 Prius tuckevalastin Off-topic / Other Cars / Everything else Discussions 60 01-13-2009 12:24 PM
Stupid prius KSIbucky Tracking, Racing, Auto-X Forum 11 09-25-2007 11:07 PM
ZPIracing Turbo Pistons ZPIracing Forced Induction Forum 22 05-29-2007 03:39 PM
And You Thought the Prius Was Expensive! redyaris Off-topic / Other Cars / Everything else Discussions 5 05-18-2007 05:11 PM
Toyot Prius YamilR Photo-Video-Media Gallery 4 02-14-2007 06:54 PM
