Does anyone know if bigger valves have ever been fitted to this head? Or if it might be possible? I have no idea what the inside of the head looks like on the 1NZ but larger valves can net more gains when used in conjunction with the P&P. Just a thought.
![]() ![]() Drives: 07 Yaris LB, 70 Mach 1, 84 5.0 Join Date: Feb 2007
Larger valves won't help unless you increase the redline or go FI. Bigger valves kill air velocity which hurts bottom end power.
I don't entirely agree with that. OF course a higher redline is going to showcase the potential of larger valves. However, with a flow bench designed head and larger valves, the hp should be avilable everywhere, not just up high. I'm not saying that the 1NZ has the potential to make more power with just valves and a head job but the potential of a stock internal 1NZ engine with just head work has yet to be realized. Many head jobs (good ones) will bear the ideal combination of performance, reliability, and drivability. This is done by balancing all of the head elements such as matching valve size and shape to seat geometry to port configuration. Bottom line: a head alone on many cars can conservatively net horsepower gains of 5 – 10% (and occasionally even more) and this is stage 1 on stock internals. But you probably already know this. Of course we will also have to get into the electronics...
#4 | |
Now, I suppose the only way to really know if the valves are too small is to spend time with the heads on a flowbench and the car on a dyno. |
If I only had the cash. A good flowed head job alone with valves, if needed, could cost anywhere from $2 to $3 grand. At Least!!
#6 | |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
I should add, though, that included balancing my rods and pistons, jet-hot coating the piston tops, and installing valvetrain. So, $3000 is a good figure for a good head job. Yup, shit's expensive.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
| What type of head unit with AUX port? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-06-2006 10:21 AM |
| ODB-II port location? | eTiMaGo | DIY / Maintenance / Service | 6 | 09-24-2006 12:27 PM |
| Port A Walls | tomjasz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 09-04-2006 04:20 PM |
| [Detail] [as to make ] Auto Laudering | Sérgio Barros | Wash, Wax, Detailing, Exterior Repairs | 4 | 08-22-2006 03:56 AM |
