Old 03-07-2012, 10:39 AM   #1
bankrobber
Drives: 2007 Yaris Hatchback
I got my Yaris with 20K miles and and I think origional pump. I noticed some spray under hood probably 2 years ago but never gave it any thought. I now have 140K miles on same water pump. The plastic resevor tank is empty but radiator is topped off. Would adding fluid in tank create more pressure possibly causing the old pump to leak
bankrobber is offline   Reply With Quote
Old 03-07-2012, 07:38 PM   #2
Happy Little Pony
Drives: 2007 Yaris HB
One of the jobs of the radiator cap is to open up if the pressure in the cooling system gets too high. If you add too much coolant the worst that will happen is that it will overflow the reservoir and make a mess.
Happy Little Pony is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 02:09 AM
Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? zimso General Yaris / Vitz Discussion 3 10-19-2010 08:17 PM
Query re: low level coolant indicator tracey540 General Yaris / Vitz Discussion 2 05-12-2010 07:01 PM
Check your coolant bottle UTVitz DIY / Maintenance / Service 13 12-16-2009 10:13 PM
