Old 01-13-2012, 11:00 AM   #109
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
2007 LB AT, 59,750 miles, have replaced wipers and tires. 0 problems.
DMZ is offline   Reply With Quote
Old 01-13-2012, 11:23 AM   #110
fj40dave
fj40dave's Avatar
Drives: '08 HB
2008
LB
Black
91193
Pass Front brake caliper replaced under warranty
Front Bumper(hit something on highway)/Tires/Oil/Plugs/Wipers/Serp Belt/Added HD Radio/Took Out Back Seat
fj40dave is offline   Reply With Quote
Old 01-13-2012, 11:44 AM   #111
traveller
Drives: Anything but Toyota
2010
5 dr Diesel hatchback
Venetian silver
<7000 miles
All warranty. Multimode Transmission clutch reset (twice), air conditioning gas leak repaired, coolant loss investigated - nothing found, corroding alloy wheel replaced, corroding alloy wheel nuts replaced, squeaky driver's floor silenced with all new under carpet components, front wheel geometry reset due to uneven tyre wear.
traveller is offline   Reply With Quote
Old 01-13-2012, 10:47 PM   #112
mryaris
Drives: 2010 Carmine Red hatchback
Hmmm.....I forgot about this thread. I posted a few years ago about my '09 hatchback, but I rolled it in Oct. '09. Here's my new Yaris' info:
2010
3-door hatch
Carmine red
45K miles
averaging 40MPG
I have had absolutely no mechanical issues with this car! The paint, on the other hand, not so good. Winter driving has taken its toll on the front end....it looks like it's been sandblasted. Oh well. The only parts I've replaced have been the wiper blades and I replace them once a year on all my cars, just as a precaution.
I love my Yaris!
mryaris is offline   Reply With Quote
Old 02-06-2012, 03:09 PM   #113
Lil Abner
Drives: 2009 3dr LB Manual
2009
3-dr Hatchback, Manual
Absolutely Red
65,000 miles
45mpg on daily 1.25 hour commute (each way)
Maintenance: Wipers, Synthetic Oil and Filter, Air Filter, Cabin Filter, Synthetic Gear Oil, Tires, and Lucas Fuel Treatment
Mods (that might change things): DF210 springs, rear MI anti-swaybar, K&N drop-in air filter, under-hood alternator wire upgrade, and other irrelevant toys.
Problems: Lots of stone chips on bumper, a few on the hood, scratched rear bumper, dent in drivers front quarter panel, and replaced front windshield (small chip cracked the glass in half within 3 hours). Who's fault? Bad Michigan Roads, and Worse Road Crews!
I inspect the car every oil change (7,500 miles) while it's on my lift, and I don't see any issues starting.
Old 02-09-2012, 02:33 PM   #114
jfgentner678
Drives: 2008 Toyota Yaris Sedan
I signed up today to see if anyone heard of the same problem my wife and I are having.
Year: 2008
Mileage: 74,xxx
Model: 4dr Sedan
Color: Flint Mica
At 62k miles, our transmission went out and was replaced (by dealer due to our warranty)
At approx 70k miles, a bearing in our AC motor went bad, and they replaced that as well.
We are nearing the end of our warranty (80k miles) and i'm praying that if anything crazy pops up in terms of major mechanical problems, it does so before our warranty ends. Any advice out there?
jfgentner678 is offline   Reply With Quote
Old 02-09-2012, 03:10 PM   #115
jengajoh
jengajoh's Avatar
Drives: '07 Yaris Hatchback
Year: 2007
Mileage: about 65k
Model: 2 DR hatchback
Color: Bayou Blue
Been averaging only 27- 29 mpg. I do mostly around town driving, not much highway driving. This is disappointing.
In the first year of owning the car I had to have the passenger seat replaced because it wasn't locking. I also had the turn signal- light mechanism replaced because whenever I turned on my signal my high beams would come on.
It's been great otherwise.
Maintenance: Oil and filter changes, wiper blades, air filter & in-cabin air filter, tires, and a belt replaced.
I've had the car 5 1/2 years now and still haven't had to replace break pads.
I have some scratches, a lot from rocks and pebbles on the road, but last summer my friend backed into it, in his own driveway, he buffed out the paint scuff but there's still fairly deep scratches there.
No modifications, though I want to get the windows tinted and this evening I'm going out to buy some wheel covers and spray paint and have myself some colored wheels. That should be fun.
Also I'm new here, so hi everyone!
jengajoh is offline   Reply With Quote
Old 02-22-2012, 05:44 PM   #116
jerome
Toyota
Drives: '11 5dr/5spd yaris
Whoops. Forgot to check in for February.
Purchased 5/29/11: 16 miles
2/1/12: 3,611 miles
Average: 103 miles/wk (35 weeks)
jerome is offline   Reply With Quote
Old 02-22-2012, 07:55 PM   #117
Mead
Drives: BSP Yaris LB 2007
Fixed the title to include other info.
Let's include:
2007
3 dr
Black
32000
battery died, 2 flat tires (so far)
2 yrs ago the cheapo stock battery kept dying and later found a dead cell, luckly it was replaced under warranty. Toyota like everyone else put the cheapest battery they can find.
Recently my tires started going flat one after another while the car was parked. Apparently in 2007 there was a batch of bad valve stems that cracked at the base due to bad formula mixture. If you bot your car around 07 from the midwest check your valve stems!
Mead is offline   Reply With Quote
Old 03-02-2012, 12:37 PM   #118
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
2009
Black 3 dr
Bought March 2009
30,270 miles
I think I've had atleast 2 flat tires, only replaced one though.
No major issues. Been getting regular oil changes & filter changes.
At 30,000 maintenace I was told I needed to 'Clean & Adjust rear brake shoes'. This was done.
I was also told I need to do a brake fluid flush & Fuel injection & throttle body cleaning.
Have not done these, and havent decided if I need to. Some people say to do it, some don't..
wiirenet is offline   Reply With Quote
Old 03-08-2012, 03:58 PM   #119
brg88tx
Drives: 07 Yaris Sedan, Auto
not the owner, but was just looking through fuelly and i saw this owner with over 203,000 miles on the ODO
http://www.fuelly.com/driver/n9qgs/yaris
brg88tx is offline   Reply With Quote
Old 03-13-2012, 02:07 AM   #120
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
2007 blue yaris hatchback
automatic
83k miles on it...
40k miles tires replaced, 59k miles water pump and serptine belt replaced by warranty.
wipers replaced at ?? k miles.
average 31-32mpg full tank.
yaris4062007 is offline   Reply With Quote
Old 03-13-2012, 08:28 AM   #121
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Just hit 95k yesturday
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 03-13-2012, 12:12 PM   #122
enviri
enviri's Avatar
Drives: 2010 Yaris
2010 5dr
39k mi
tires replaced twice due to nails on road
replaced control arm bolt from TSB
Dead battery replaced with junkyard yaris battery (FREEBIE!)
Front caliper leaked fluid a bit, my fault for not tightening during bleed after putting in OEM BBK
avg 29-33 mpg
Old 03-13-2012, 03:07 PM   #123
Cutie Pie #2
Drives: 2014 Honda CR-V LX
2008 yaris
Blazing blue
60,000
Running good, still getting around 35 mpg.
Problems: None other then a hood rattle that no one seems to be able to fix tried about ten places. I've just learned to live with it.
Done all required services, been pleased with car so far!
Cutie Pie #2 is offline   Reply With Quote
Old 03-13-2012, 05:50 PM   #124
Perpetuous_Dreamer
Drives: Yaris 2007
2007
Hatchback
Grey
78000
No problem so far, only routine maintenance (oil, transmission fluid and coolant change). Not even brake pads or tires. Once battery died about three years ago due to my fault but steel functions like new)
Perpetuous_Dreamer is offline   Reply With Quote
Old 03-24-2012, 10:58 AM   #125
yarista
Drives: 07 Yaris 3dr, 09 Yaris 4dr
2007 Hatchback
81k
No problems so far
2009 Sedan
37k
No problems so far
yarista is offline   Reply With Quote
Old 03-29-2012, 09:56 AM   #126
pj. olsson
Drives: Toyota Yaris TS 5 Door
2007 Yaris TS
89000 KM
One Problem with ABS Sensor, not terrible! :-P:-P:-P
pj. olsson is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 07:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 02:11 AM
