#973 | |
Still waiting on the close ratio gear box.
#974 |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Are you still running VVT-i in this car? Does your tuner/management have control over the that?
www.microimageonline.com |
#975 |
Yes, still running it and the AEM controls it.
#976 |
"Know it all"
Great results! I'm real excited to see that these actually work. I'd be curious to see if any top end gains or benefit from disabling VVT-i and running set or manually adjustable cam gears. Might loose more torque though...
Can't wait to see what the turbo spec Jun cams do for boosted cars
#977 | |
#978 | |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
#979 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
pics
From runoffs
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#980 |
Off to Willow Springs tomorrow, testing radial slicks on the 99.
#981 |
We are making progress on the Kaaz close-ratio gear set. Kaaz USA was able to track down the synchros we need, and are making modifications to two of the gears for a proper fit.
I would imagine that means I will spend my weekend in the place I am getting way to familiar with, on the floor pulling a trans out.
#982 |
2ZR swap. DO IT! Ask how!
Wow, I'm surprised to hear that there's so much involved in fitting those gears. The C-56 gears went in without much fuss, but I'm stalled on funding for replacement parts and the LSD.
#983 | |
![]() Turns out the gear itself is not to wide, but the collar at its base, that combined with the Yaris synchro made it bind up. And it is only the 3rd and 4th on the input side that is the challenge. They take a little bit off the collar and install the Celica/MR-S synchro its supposed to fit. Fingers crossed.
#984 |
Back in my Honda racing days this guy was the man for alternate gear sets, he can probebly help you out if need be. He is a multi-time SCCA Champ and really knows a thing or two about gearboxes.
http://www.housemanautosport.com/ racerb
#985 | |
#986 | |
#987 | |
racerb
#988 | |
C56B LSD You may actually have the same problem we did and not know it yet if you have not put it back together. You wont know until you jam it all in the case and measure the drag when you spin it.
#989 |
It's definitely a C56A then, as it's an open diff. The assembly goes together at the moment, but I haven't checked the torque yet. I have to replace the output shaft inner bearing (the one in the bell housing) because the C56 has an inner race on the roller bearing, whereas the C50/C59 doesn't, and the groove where the snap ring holds the inner race on the shaft sits right in the middle of the rollers. I'm assuming that you weren't able to get the torque set properly with any of the shims, which prompted you to investigate?
#990 |
The trans out of the 99 is in the shop for its new guts. With any luck I will have a close-ratio box by Friday.
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
