Old 03-14-2012, 12:15 PM   #1
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
You never cease to amaze. thank you. Ill try it. So I take it that it doesnt matter which way I spin it all the way too?
Club SHIFT
Old 03-14-2012, 12:53 PM   #2
TickleTimeTim
Free Mustache Rides
Got it back on thanks. Now how d i get airbaf light off? Disconnect battery?
Club SHIFT
Old 03-14-2012, 01:00 PM   #3
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 03-14-2012, 01:34 PM   #4
TickleTimeTim
Free Mustache Rides
You're the man. After school, before work, ill try to remove the light. This jumper wire...excuse my stupidity, but would speaker wire work? Would that bridge it okay?
Club SHIFT
Old 03-14-2012, 01:37 PM   #5
A paper clip or any piece of wire, of which the bare ends will fit into the holes, will work.
Old 03-14-2012, 02:15 PM   #6
mr_miles
Drives: 2013 Yaris
what kind of aftermarket wheel and hub did you get? :p
Old 03-14-2012, 06:58 PM   #7
TickleTimeTim
Free Mustache Rides
Some eBay detachable wheel. I have a thread called updated pics that you can see it in. I already miss the smallness of that wherl, but it wasn't luxurious feeling. Maybe ill get a sion wheel later on.
Club SHIFT
Old 03-14-2012, 07:41 PM   #8
TickleTimeTim
Free Mustache Rides
Tried this but a random s/p light started flashing and my airing light did nothifng. What did i do wrong? Wrong port?
Club SHIFT
Old 03-14-2012, 08:10 PM   #9
You are probably on the wring pins. You might want to try from the top of the connector (by removing the change cup). On top it is the White wire with the black stripe to the pink wire.
Old 03-14-2012, 12:55 PM   #10
Correct - Either way you'll hit a stop. Once you do it is 2.5 turns back to center from either stop.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How to remove steering wheel emblem vdubs4ever Cosmetic Modifications (Exterior/Interior) 6 09-17-2011 09:36 PM
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-29-2010 11:50 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
